VEMS Idle settings without Idle Valve using Ignition
  • gnutz2
    • Aug 2006
    • 928
    I have a tried and tested method of open loop knock detection and ignition retard.
    The hardware i made myself. And all you need then is an auxilary input which can interpret the digital on off signal as knock, then ratard the ignition.
    Im sure it will be compatable with VEMS, does enyone know what auxilary inputs and outputs VEMS has.
    The ONLY S2 Golf!
    10.42@138mph
