if you need to go back to 1.1.27 follow the following procedure (the issue is that 1.1.44 floods the serial line with the AIM communication protocol, which prevents the firmware reset from working right):
1) edit the file 'upload-firmware12x12.bat' in the 1.1.27 megatune folder. Change the line that starts with: tools\megaloader.exe to read like so:
tools\megaloader.exe firmware\vems12x12.hex -wE -c com1
where "com1" is whatever your serial port is.
2) turn ecu off. Make sure no megatune or other programs are running that might try to use the serial port
3) shove a bent paper clip between pins two and three of the serial connector
3) power on ecu. wait 3 seconds. remove paper clip and connect serial cable to your computer.
4) run the upload-firmware12x12.bat file. It will ask you to press a key to continue etc. The process should complete successfully.
Try this for a 1.1.44 audi basemap. Configured for 12x12 tables, 60lb/hr fuel injectors, GT3071 turbo, high output TTL coils. Cam hall inverter.
http://www.efiexpress.com/downloads/...ll_ttl_ls2.msq
