Vems Carbon canister freq valve
im going to try it hopefully today. Im not sure if i will see any change though. Marc has given me instr. to set it up on the misc. outputs. It doesnt have a duty cycle to appoint,but i presume that by inputing high and low values it will be done on it's own. -
I would be interested if you get it working. I am waiting for my VEMS to arrive
it could mean that the duty cycle incrases with revs so long as you are in vacuum mode when driving.As soon as you get into boosting then it shuts off.Leave a comment:
there is a misc output with which you can control the valve.im planning to do this in the near future to see results. in any case though it doesnt make a difference. so far i dont use it and everything is fineLeave a comment:
Pls. Help me
I think it show (%load). But what block No. tells N75 duty cycle in VagCom meassure block.
Let me know if you have complete description about Block Numbers.
(S4S6 are not same as 1.8T,TT)
Thank for your helpful.
S4 Y92 Manual Chiped 264hp 1.9 Bar SpringLeave a comment:
Is this already implemented in one of the firmware versions?Leave a comment:
Did some quick testing of this at the weekend.
I confirmed the EVAP duty cycle is ZERO under any positive boost.
Its about 5.5% cycle time at idle - its NOT gonna interfere with mixture in any significant way.
The duty cycle increases with revs - dont really know why - its not like there's more fumes to be treated at higher engine speeds. I think I have a log file for that data.Leave a comment:
Yep - its the third line from the tank towards engine bay... On an ABY the evap canister hides behind right front wing, but on 3B its way up front of the engine in a bizarre location from memory. If you follow the pipes you'll see where it comes to the IM near the throttle body - there's a blue coloured connection where it meets up with the PCV pipework.Leave a comment:
anyone have a picture of where this ipe is on the engine bay? or is it the line that travells down the car with the fuel lines??
AntLeave a comment:
it does little harm to remove it.
keep the pipe from tank open. block all the others or better still remove them and block at the inlet to make it cleaner to look at. also potentially ridding you of some mini vac leaks.
the can after all this time much like a water filter is useless anyway.
we used to remove the can on the G60 corrados to free up the space in the inner wing area for filters. also removed lots of lines around the inlet.Leave a comment:
vems
Thanx Paul
It should be wary easy to control by Vems. Then. I will power it on below 100 kpa. And above 2000 rpm so it don’t infect the idle. Then it will be active in a small window when leaving the throttle.
Due this sound ok ?Leave a comment:
ah ok, that makes sence, but surely when running VEMS or i assume any other after market ECU the canister doesnt function? does this not create dangerous pressure? also is it not potentially angerous to remove it?
i'm by no means having a dig at after market systems here, especially not as your trying to include it, just trying to figure this one out.
AntLeave a comment:
Close but no cigar...
The carbon canister treats any petrol fumes/vapour that build up in the tank and allow them to be burned by the engine at certain times.
In the old days a petrol tank just had an air vent via a small tube to stop build of vapour pressure in the tank getting dangerous - such as a car parked up on a hot day. Nowadays it is viewed as a heinous crime to allow such untreated fuel fumes into the atmosphere...Leave a comment:
