Vems Carbon canister freq valve
    Ah yes I see on ouput channel selector I259 output channel1=6
    Do you still use these settings?
    min rpm = 2200
    max rpm = 4000
    Max tps positon = 3%
    Maximum manifold pressure = 80 kPA
    • A80Avant
      • 10873
      • Country: Greece
      #32
      i think so, i have to see when i get back to my laptop at home.
      will update
      • A80Avant
        • 10873
        • Country: Greece
        #33
        correct. these are the settings i have on the misc output
          Then if you don't mind I will be using the same settings
          • A80Avant
            • 10873
            • Country: Greece
            #35
            haha
            why would i mind? if it works by all means, use them!
            I am not a tuner, so if i want to post some settings that work for me i do it.I dont hide them. That is what 'was' nice about VEMS, until recently.
