Hi.
I have one problem with my VEMS config.
When I start the engine when he is cold, rpm are horibly small (~500). I think that I have wrong warmup enrichment settings. Could someone write any checked and good working setting?
I use peter_jensen IAC valve config, and when engine have ~90*C rpm are good.
When I use only Ignition based idel control, on cold engine rpm are rolling up'n'down (form 500 to 1300).
