Let me try...
1. Fit an adustable FPR - 034 do one
2. Fit a fuel pressure guage
3. Fit a wideband O2 sensor and AFR guage
4. Hook up a relay for the fuel pump to make sure its getting closer to 14V instead of 12V - flows more fuel
By increasing fuel pressure you should be able to dial in more fuel - try adding small amounts of E85 at a time.
On the AFR guage you'll want to see approx 12:1 at WOT - adjust fuel pressure for that.
See how much E85 you can run to that level and keep baseline fuel pressure below 5bar is my recommendation.
Doin rough maths I'd say 5bar gets you ~20% more fuel and so you should be getting towards 50:50 mixes of E85 and petrol. Don't quote me on that - just a rough swag here on a Friday night watching U2 on tele !
For 100% E85 running you'll need approx 40% more fuel then on pure petrol - with a switchable chipset (hint hint - talk to me) you can get more fuel than by just tweaking fuel pressure alone - trouble here is that you don't want silly fuel pressure if you can avoid it - and you''d hit the limit on stock injectors pretty soon. So...
5. Fit larger fuel injectors - maybe 440cc or 550cc rated - dont think you'll need to go as extreme as 650cc on a K24 turbo - plus look how low the fuel pressure is when Espen runs on petrol with injectors that size.
