I try to Install Firmware but after instalition vems tune say that ecu not connected.What to do?How to get it run again?
What is needed to run with VEMS?
I'm sure in the early vems ecu's a wire had to be switched, infact GazzaG60 was the one who pointed it out
You would be best asking who you bought the ecu from and also checking your injector output settings are correct.
Have you checked for spark and fuel?Comment
hello,i bought vems v3 (plug and play version for aan, aby, adu) from here http://shop.vems.hu/catalog/vems-motronic55-p-122.html , so what can i say....good thing for making your car crazy
Spring ir here everyone wants to drive the car from the garaze (from winter sleeping or after good mods)
by the way aan and aby ecu's are the same as this vems v3 (3b pin outs are different).i used it for aby and tested in aan.it's working. http://www.cardomain.com/ride/299250...i-coupe/page-8
