Vems Map + Injector Sizing
  • Bram
    • Aug 2006
    • 2582
    Originally posted by Jamo
    I found http://www.efiexpress.com/catalog/ar...?articles_id=1
    Damn fine webpage so yes injectors is just a calculation very good came up with a theoretical
    750 cc injectors rated at 3 bar running at 4 bar = 866.03 cc / min
    Therefore Stroker req+fuel = 6.49 * ( 2521.69 / 5 / 866.03 ) = 3.78 * .75 = 2.84
    I'm having a play and seeing what I can learn before deciding what to do with the ecu, does seem though there is a lot to learn
    In your calculation you should use the @3bar ccm number. not @4 bar. Or it must be that a UrS4 runs an FPR of 3 bar???? I thought it was 4 bar
    At least this is what is stated in Marc's instruction:
    As a guideline, set req_fuel according to the following calculation: req_fuel = 6.49 * (D / N / I) where D= engine displacement (ccs), N = number of fuel injectors, and I = injector flow rate (cc/min). To allow for finer grain fuel control I usually use 75% of this calculated number. So for an urS4 with stock injectors (280 cc/min @3 bar), req_fuel = 6.49 * (2200 / 5 / 280) = 10.2 * .75 = 7.65
      The injectors are rated at 3 bar the ABY runs at 4 bar so convert injector rating from 3 to 4 bar = 866 cc
      The example is just an example, on his example map from the download link Req Fuel is set to 6
      280 @ 3 bar = 323.32 @ 4 bar
      6.49 * ( 2226 (the official engine size ) ) / 5 / 323.32 * 0.75 = 6.7
      So it's closer to the actual map value than 7.65
      • Bram
        • Aug 2006
        • 2582
        OK I think I understand, then Marc did not do it very punctual in his calculation example as he should have used 4 bar injector flow rate and use the correct displacement. I think your assumptions are correct.
        So for my engine spec it should be:
        630 @ 3 bar = 840 @ 4 bar
        6.49 * ( 2226 / 5 / 840 ) * 0.75 = 2.58
        • GazzaG60
          • 4133
          sounds correct. i dont quite work mine like that. that gives a lower ms figure than the way i used.
          what i will do is mod the map to reflect those figures. that should tell me if marcs way of req_fuel is better.
            630 @ 3 bar = 727 @ 4 bar!
            • GazzaG60
              • 4133
              how did you work that out jamo
                Square root of new pressure / old pressure multiplied by old pressure...........
                Or just use the RC calculator http://www.rceng.com/technical.aspx
                1 bar = 14.5 psi therefore 4 bar = 58 psi
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #23
                  and the oem RS2 injectors rated to 4bar,for how many horse power at the crack will be valid??? 380hp??
                  • GazzaG60
                    • 4133
                    good spot that jamo.
                    i used to use an old calc like that but the calculator is much easier.
                    • Bram
                      • Aug 2006
                      • 2582
                      I am learning everyday! Great that you pointed this out!
                      • Bram
                        • Aug 2006
                        • 2582
                        So again my setup
                        For my engine spec it should be:
                        630 @ 3 bar = 727.5 @ 4 bar
                        6.49 * ( 2226 / 5 / 727 ) * 0.75 = 2.98
                        • Bram
                          • Aug 2006
                          • 2582
                          370-380 max @ 3.8 bar FPR
                            RS2 injectors
                            360 cc @ 3 bar
                            405 cc @ 3.8 bar <- FPR of the RS2
                            416 cc @ 4 bar
                            They will support 400 bhp, Mihnea has quoted as such IIRC on the forum
                            Anyhow back to VEMS there are injector threads covering this
                            • repo
                              • Dec 2004
                              • 893
                              deka 006 flow chart:
                              Your calculation was suprizingly close.
                              e: injector CC/min = hp in our precious I5 engines.
                              • Bram
                                • Aug 2006
                                • 2582
                                @ 3 bar I presume?
                                So Siemens Deka 006 630ccm@3bar injectors in our cars (using a 4 bar FPR) should be good enough for around 630 crank HP. I think Paul mentioned this before as well in another thread.
