Vems
  • powaw
    • Jul 2009
    • 80
    Vems
    I was digging around on here some more and ran across the links to the efiexpress site. http://www.efiexpress.com/catalog/pr...&products_id=1
    Has anyone dealt with them? Opinions on using this setup in my AAN/944 swap.
    currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
    see the AAN/944 swap at Nina's 20VT
  • A80Avant
    • 10873
    • Country: Greece
    search the forums. Marc is actually a sponsor now.
    • a4kquattro
      • Feb 2005
      • 411
      fire away with questions, I have nothing but happy customers here, and I work hard to keep it that way
      Marc Swanson
      Proprietor, EFI Express
      95.5 //S6 Avant
      90' Coupe Quattro V8 4.2L twin turbo
      93' //S4
      83' UrQ
      97' F250 7.3 diesel
      • powaw
        • Jul 2009
        • 80
        It says pnp. Does it use all of the stock sensors? Can it eliminate the maf sensor? Does it still control non ignition functions like the after run coolant pump? Does it use the MFTS? I've been looking on the wiki (not very well designed) and the forums for answers, but haven't invested alot of time yet. Last year I was looking at putting the MS system on the 944's stock motor, but stopped when I was seeing the issues with using the OEM timing sensors. I didn't want to switch to a crank mounted tooth wheel. It looks like VEMS uses the OEM timing sensors. So I guess basically if I installed it, what are the loose ends that will have to be tied up? By the way, thanks for replying!
        • a4kquattro
          • Feb 2005
          • 411
          Originally posted by powaw
          It says pnp.
          because it is
          yes, other than...
          the MAF is not used. You can remove it completely. Most VEMS users mount an air filter directly to the turbo, but this is not a requirement. you can still leave the stock MAF in place if you want to.
          as I mentioned in the other thread, the afterrun coolant pump is a discrete circuit with no interaction to the ecu (same deal with the cruise control system). Works on VEMS.
          No, and neither does motronic. The MTFS is actually used by the HVAC system. The coolant sensor used by the ECU is located at the back of the cylinder head.
          no argument here..
          correct.
          click here for comprehensive installation instructions:
          http://www.efiexpress.com/catalog/ar...?articles_id=1
          Not a problem, fire away with any additional questions.
          Marc Swanson
          95.5 //S6 Avant
          93' //S4
          83' UrQ
          97' F250 7.3 diesel
          • powaw
            • Jul 2009
            • 80
            Do you have a document that details the vems operation in this application? Does it have usb connectivity? Will there be any hardware changes in the near future?
            • powaw
              • Jul 2009
              • 80
              Nevermind on the usb part. I found it in the instructions.
              • a4kquattro
                • Feb 2005
                • 411
                hardware no, software / firmware YES. the new firmware has some pretty exciting stuff in it, like the ability to taper boost if EGT gets too high.
                Marc Swanson
                95.5 //S6 Avant
                93' //S4
                83' UrQ
                97' F250 7.3 diesel
                • Bram
                  • Aug 2006
                  • 2582
                  Marc,
                  What is the new version number and when does it come available?
                  • powaw
                    • Jul 2009
                    • 80
                    Braum are you using VEMS? How do you like the turbo you have installed? What rpm does it hit full boost at? Thanks
                    • A80Avant
                      • 10873
                      • Country: Greece
                      1.1.57 has been used by some suppliers but im waiting for the official update to be 100% certain it works properly
                      • max_s2
                        • Mar 2006
                        • 498
                        • Country: Latvia
                        I'm running 1.1.53 on my S2. No probz so far
                        • GazzaG60
                          • 4133
                          glad its going well Arnis. did the settings i sent help?
                          • a4kquattro
                            • Feb 2005
                            • 411
                            has the vemstune issue been resolved in 1.1.5x that displays 255 as the max instead of actual KPA in the VE table?
                            Marc Swanson
                            95.5 //S6 Avant
                            93' //S4
                            83' UrQ
                            97' F250 7.3 diesel
                            • A80Avant
                              • 10873
                              • Country: Greece
                              no it hasnt.you just reduce it in your mind...haha
                              basically on a 400kpa sensor: 255=400 and then you need to divide it to make the correct numbers.
