VEMS high AFR on idle
no
say you have an idle of 1.25 and your req fuel is 3.8 lowering this figure will make it leaner.
thye req fuel is how long the injector has to be open for stoich. so yours is set to 3.8ms. lowering that dictates the injector is bigger so needs less opening time.Comment
I will try 3.9 thenComment
all values in ve will be out if you change req_fuel.
it will need extensive changes. if your only just starting its worth doing though. saves lots of changes later.
as Vas says. change the reqfuel then set the ve for idle. use the change in numbers (expect to add 10 or so to ve for that change) as a guide for the rest of the ve chart.Comment
petrol aint cheap.
you can dial it out till it starts to pop a little then put a fraction back in.
thing with these cars. well any 4x4 is it drinks too much. i get good returns on the motorway due to miser tuning.
if you set more pressure zones below 100kpa you can fine tune more with the bigger injectors and get much better cruise and still have the zones for boostComment
i should do that with the bigger turbo actually.
for now,im getting about the same(maybe slightly better) economy than the motronic on cruising. a bit worse on high boost though.
on idle i have it on lamda=1 and with the use of the isv valve it works like a treatComment
Yesterday I noticed when starting the car the second time and the engine got warm the EGO kicked in and raised the idle RPM to 1100, where the lambda also showed 1.02 on idle
Now I know this is a closed-loop lambda setting done automatically by the VEMS ECU. I have EGO disabled atm.
Would it be possible that the idle VE values can be set with the VE learning (auto-tune) feature op Megatune?Comment
il;l chat with you regarding the idle control as i dont run it still. could never get it to work when driving properly. still gotta fit the diode too.
bram - i have a similar setup. standard bore, wagner setup, sc61, reverse inlet, seimmens injectors, 3" system. those targets work fine with the seimmensComment
