VEMS firmware versions
so basically, if you think that once the tune is done on any firmware, you will be able to succesfully do a transfer to the new tables, then you are ok to use the 1.1.27 and then switch to the 1.1.62.
who is going to be tuning your vems by the way?Comment
1.1.62 in an S2 http://www.vems.hu/wiki/index.php?pa...Page%2FAlexHoy
Vas has noticed something that Vemstune has a bug in the rpm vs boost table is wrong. I've been thinking this must be an .ini problemComment
Go to Boost Controller Settings make sure there is a PID entry in the Boost P setting I've entered 250
Set the Boost Config to 32, PWM Period to 16ms and changed the target to boost-target
Closed the config went back into boost vs rpm curve and it showed RPM and allowed me to enter rpm values such as 4000
I've noticed the table name changed as well
Just checked and it works with either config selected.
Table looks the same the word curve goes, I think it is a bug but if you change the settings then change it back it works.
The boost pwm table also updates with the rpm values entered nowComment
Each to their own, I have an EBC also but there are fault conditions in the later vems firmware that can reduce boost so i'll be using that.
Vas have you seen anything that can covert the msq to the vemstune?
Looks like everything has to be entered manually?Last edited by Jamo; 9 November 2009, 15:05.Comment
no but it controls boost well and a firmware update will make no difference whatsoever.
get the mapping correct and it should be ok.
precautions are for those who throw caution to the wind or dont understand or maybe worry about the lack of precautions or both/all.
id expect Repo will use his skills rather than potentially troublesome precautionary code. i am 100% sure it will be mapped with those off and maybe turned on at a later date. skills over precaution.
how much use is reducing boost on a melted piston. the same as how much use is retarding timing once the damage is done. you gotta set thresholds first.
i can see why you want them and applaud your seaching for the best feature set your suit your needs.
my experience so far with vemstune has not been the best. maybe why 1.1.27 is still so popularComment
