Priming, cranking and afterstart with 750cc injectors
  • button
    • Dec 2007
    • 99
    • Country: Poland
    Can you look at this config:
    SendSpace lets you transfer large files quickly and securely for free. Enjoy hassle-free file sharing today.
    I can't cope with the normal starting of the engine. Whether the engine is warm or cold I have a very long spining time and move the throttle to start the engine. Sometimes, when the engine for a long time will not catch, after start it able to show a trigger error.
    Injectors are LowZ 750cc/min@3bar with series resistors.
    Audi 90 quattro '88 4.2V8 on VEMS
    Audi S4 C4 Avant 2.2T '92 @ 2,5TDI
  • button
    • Dec 2007
    • 99
    • Country: Poland
    Does someone have any idea?
    • gnutz2
      • Aug 2006
      • 928
      Low Z injectors tend to be c r a p.
      What size resistors do you have in series, any thing more then about 2.5 ohm and they will struggle to open properly.
      Resistors need to be about 35 watt too.
      Personally i have wastad a lot of time and money using these injectors, i wouldnt even go there again.
      The ONLY S2 Golf!
      http://www.s2forum.com/forum/showthread.php?t=19402
      10.42@138mph
      https://m.youtube.com/watch?v=0wnkkOfFpXg
      • pnanassy
        • Dec 2004
        • 287
        • Country: Hungary
        Controlling them is the key.What ECU do you have gnutz?DTA?
        Peter Nanassy
        Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
        http://www.carstyling.hu/car_shower.php?id=19845
        http://www.youtube.com/watch?v=FYOVA_285Rs
        • button
          • Dec 2007
          • 99
          • Country: Poland
          I use VEMS.
          I have, in this cars ~7.8ohm 50W resistors.
          When the engine start's it running realy good, and it haven't got problem with idel rpm.
          Here is the screen form priming, cranking and afterstart setup:
          • gnutz2
            • Aug 2006
            • 928
            Yes DTA, i spoke to allan the technical guy at dta and he told me to use 2.5 ohm resistors.
            The engine ran ok but nothing like as good as when on seimens 630cc high z.
            I also had a really serious problem with the injectors leaking fuel into the engine when not in use. This caused misfires at best and also caused a fire.
            The ONLY S2 Golf!
            10.42@138mph
            • pnanassy
              • Dec 2004
              • 287
              • Country: Hungary
              Yeah,DTA is not the best when Low-Z injectors come into the picture.However,more advanced ECUs control them easily.For example i got 1200cm3 on my 2.2L I5 and got a nice idle 1.00lambda.
              To the hardware issue you had,i dont think its a low or high Z related...
              There are special low Z injector driver boxes,worth a try?!
              But sure,the new tech. high Z injectors are good.Just experimenting with a 1000cm3/4bar on the stroker.Looks ok so far.
              What was the PW where you had problems?
              Peter Nanassy
              • button
                • Dec 2007
                • 99
                • Country: Poland
                log from starting the engine (unsuccess)
                • gnutz2
                  • Aug 2006
                  • 928
                  I only ran them outboard so never had to idle the engine with them. the P/W was allways from about 5 to 10 ms.
                  Like you say maybe they are just bad for DTA.
                  The ONLY S2 Golf!
                  10.42@138mph
                  • button
                    • Dec 2007
                    • 99
                    • Country: Poland
                    Maybe someone would like to share with his own settings of priming cranking & afterstart?
                    • button
                      • Dec 2007
                      • 99
                      • Country: Poland
                      OK. Problem solved. The problem was in the injectors. After instaling Siemens 630cc/min the engine starts up
                      • pnanassy
                        • Dec 2004
                        • 287
                        • Country: Hungary
                        what was the problem with the 750's?
                        Peter Nanassy
                          Low resistance injectors with resistor packs, i'd say there was a driving issue
                          • pnanassy
                            • Dec 2004
                            • 287
                            • Country: Hungary
                            Im running 96lbs with 4+ bar fuel pressure,and resistor pack.Car starts for the first crank.
                            Peter Nanassy
                              Not all resistor packs are created equally, I wouldn't entertain using them
                              What's the point of having low z injectors if your have to run resistors with them?
                              That's why I bought high resistance 750cc RC Injectors
