Using AEM EMS6860 on AudiI5
  • tomye1978
    • Oct 2009
    • 11
    Hello,
    I want to use a EMS6860 to an Audi I5 turbo engine.
    Who has a runing system and can give me some information about the trigger and sync signals. I wanted to use 5 teeth on the flywheel and the original sync from the cam. I try a lot but it doesn't work.
    Thomas
  • button
    • Dec 2007
    • 99
    • Country: Poland
    Talk to Albert. He uses the AEM EMS, but with 12-1 (or 12) trigger wheel.
    Audi 90 quattro '88 4.2V8 on VEMS
    Audi S4 C4 Avant 2.2T '92 @ 2,5TDI
      The flywheel sensor is looking for the one tooth only ( flywheel pin )
      For details on the Audi trigger see here http://www.vems.hu/wiki/index.php?pa...%2FAudiTrigger
      • button
        • Dec 2007
        • 99
        • Country: Poland
        Jamo
        It seems to me, that the AEM doesn't support AudiTrigger.
        tomye1978
        I understand, that you in-house fit the extra 4 pins on the flywheel?
        • tomye1978
          • Oct 2009
          • 11
          Yes, I put 5 teeth on the flywheel. Started with 10°BTDC
          Thomas
            Are those pins magnetic that you've put in the back of the flywheel?
            • tomye1978
              • Oct 2009
              • 11
              I have a good signal from the flywheel. This isn't the problem.
              The ecu can use the signal, too but no ignition when I trie 10 teeth with sync signal in the ecu.
              There is ignition with 9teeth or 5 teeth but nothing with the 10 teeth.
              Thomas
                I suggest you contact AEM for advice regarding this non standard setup.
                • GazzaG60
                  • 4133
                  isn't 60-2 the tried and tested.
                  maybe a custom trigger setup for the i5 standard triggers?
                  • button
                    • Dec 2007
                    • 99
                    • Country: Poland
                    So ECU see rpm, but spark doesn't appear?
                    • GazzaG60
                      • 4133
                      cam sync
                      • button
                        • Dec 2007
                        • 99
                        • Country: Poland
                        I also bet malfunction of camsync.
