yes, that was another suggestion from the developers, that the fuel resume is as high as 800rpm from your idle, but in my car that caused hiccups esp. when cold and driving at very low revs in the city. This is why i finalised using 1300-1400rpm on resume/cut respectively.
if your car is cutting at different rpm than what specified there may be a problem with the accuracy of the rpm signal. What flywheel do you use?
