Problem uploading VEMS firmware
  • a4kquattro
    replied
    Originally posted by QuattroFever
    Is it a problem if it says 1.1.68 instead of .70 (if the config.ini is not right)
    nah, thats normal. many firmwares share the same vemstune.ini +/- a few releases since the changes were not in features, just bug fixes etc. So the ini stays the same.
  • QuattroFever
    replied
    Originally posted by a4kquattro
    vemstune might list the firmware as 1.1.23 if it doesn't have the 1.1.27 config ini installed. The same thing is true of 1.1.70, often it will show as a 1.1.68 ini file depending on what ini files are installed.
    yes, in vemstune you can also tune files offline like you can with megatune.
  • a4kquattro
    replied
    Originally posted by Jonas_R
    Thanks Marc that seemed to work, I had a saved config. But what if I want to set the basic AAN spark table that is in the vemsproject folder. Is that possible without the ECU connected?
    yes. you can drag and drop a .vemsproject file over an open table, and it will import the settings for that table from the source file. Pretty cool feature, actually.
    replied
    Just a couple of quick questions:
    What is the difference between the firmware 1.1.27 if you use Vemstune and select Audi 12x12 or if I use the firmware upload bat from efiexpress? I tried to use the method Jamo described earlier in the thread but VemsTune list the firmware as 1.1.23?
    When I did the firmware upload I selected in Vemstune I selected 12x12 audi from the 1.1.27 folder and the I choose to add "air patch PTC 425 260" and "coolant patch NTC 1900 256". So is this just as good as using EFIexpress firmware bat?
    Is it possible to start VemsTune in offline mode like you can with MegaTune?
    Certain version share the same config so if you look it actually says firmware 1.1.27 and config 1.1.23
    I'm using 1.1.70 but as it's config is the same as 1.1.69 so it shows firmware 1.1.70 and config 1.1.69
    Config files are only created when there are different options in the new firmware AFAIK
  • Jonas_R
    replied
  • a4kquattro
    replied
    I have not used a strobe light before but do just need to flash a the timing belt? SInce I'm 034 coils I have spark cables so I guess that should be fairly easy to setup.
    ah, very easy then. you clamp around the #1 spark plug lead.
    How did you go into offline mode in Vems?
    start vemstune with no serial cable connected to the ecu There is also a button somewhere that does it too, but I always just physically disconnect my serial interface. Then load a .vemslog or .vemscfg to mess around with a config.
  • Jonas_R
    replied
  • a4kquattro
    replied
    Is there actually a place on the s2 where you can use the strobe gun or do you need to remove loads of stuff?
    I've done it before by clamping on the wires off the power output stage. isolate the one for #1 cylinder, and a good strobe light will flash on it.
  • Jonas_R
    replied
  • Jonas_R
    replied
    Yeah oki guess that makes sense.
  • A80Avant
    replied
    that is something best checked with the strobe light.
    i think mine is 58 now but used to be 57 or something.
  • Jonas_R
    replied
    Auditrigger - I have a quick question, should it be 56 or 58 at "TDC after the trigger"? See attached picture.
  • Jonas_R
    replied
    How do go into offline mode in VemsTune did seem to be able to do it?
    When uploading your firmware marc should I run temperature patch as well afterwards?
  • a4kquattro
    replied
  • Jonas_R
    replied
