VEMS P&P Box and Led Display placement ?
  • Tuna
    • Jun 2008
    • 80
    Hi.
    Were is the best place to put the VEMS P&P Box and the Led Display ?
    would be good with some tips and pics.
    I would not put the led display in the air intake.
    Regards
    Johan
  • GazzaG60
    • 4133
    hi there.
    theres only one place to put the pnp vems. thats on the motronic connector where the factory ecu is.
    the LED display. id have thought swomewhere you can see it. i haev a vems EGT/AFR gauge in a air vent.
    with the pnp swap the crank 2nd VR polarity and it should be ready to fire up.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      here is my solution
      • Tuna
        • Jun 2008
        • 80
        Thanks....
        Hi
        Thanks for the advice.
        i wondered if it was possible to put the box where the factory ecu was located,or if i had to put it in a bracket of some kind. ?
        Regards
        Johan
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          i found that it fits where OEM is, if you remove the metal bracket all together
