After starting the stroker i started to map the car and noticed that when i go drive at lets say 2500 RPM and press the clutch the revs are falling and the engine simply stalls. When i let the car slow down into gear and let it go in gear till 1000 RPM and then press the clutch it idles nicely.
Anyone has an idea?
Tested with PID idle disabled and enabled no difference.
here are the settings i currently have (engine difference appart tha the new one is a stroker i also have a single mass lightened flywheel).
Anyone has an idea?
