Vems firmware 1.1.81 has release status
    from idle
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      #107
      do you think it may have something to do with the injection angle?
        I don't know, I set the angles all to 210 as per other firmwares as a test and it was no better. I need more time to play with it but the car was so sluggish I had to back out
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          #109
          i see
          is it possible to set that feature completelly off? something like using rpm of 25500 on all bins?
            I'm not sure the injector trim was the cause to be honest, I know Alex Hoy had problems with the firmware due to a hidden conflict which made his car misfire
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #111
              i see, well keep it up. i hope i dont run into a lot of trouble with mine...
                be after ADI, unless I get a chance friday to play
                • Billman
                  • 4129
                  #113
                  my acc enrichment is still not good but it was much worse with 200 angle than 400.
                  config posted here
                  Go Holset or Go RS4
                    Use the fuel film settings, see http://www.vems.hu/wiki/index.php?pa...rey%2FFuelFilm
                    • Billman
                      • 4129
                      #115
                      I will try it out....but still dont get what this fuel film is.
                      Go Holset or Go RS4
                      • Billman
                        • 4129
                        #116
                        After 2 hours of driving still crappy acc. Somehow when accelerating it goes rich after 1.5 or so seconds it goes super stays like this for approximate 2-3 seconds and then goes nice again. Can it be that 1.1.81 sucks?
                        Anyone fancy sharing a 1.1.74 map W/O timing and VE table???
                        Go Holset or Go RS4
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #117
                          but 1.1.81 and 1.1.74 have the same accl enrichment tables. As Jamo said, make sure you do not have any conflicts that can cause this problem. If i can remember you did have problems with accel enrichments before as well.
                          • Billman
                            • 4129
                            #118
                            Yes but not like this. Maybe there is some issues in the code? Anyone got it running well?
                            In the trigger settings I am just not sure about the hall diract filtering. Do I need it?
                            Go Holset or Go RS4
                              I tried to help you earlier regarding that setting, I posted in the other thread, wish you had read before commenting back!
                              • dkw_dude
                                • 555
                                • Country: Norway
                                #120
                                If you still have 0,6 sec fadeout time I would change this to 0,2 sec. Works good for me on 1.1.70
                                I also agree with Jamo in the post above, I got a better understanding after reading about Audrey's explanation.
                                Leif-Helge
                                -91 S2 VEMS and Comp Turbo
                                -12 B** 530XD Touring "S2 parts transporter, and daily driver"
