Bill
why do you need those areas so rich in the first place? if accel enrichments are completelly off, OR if you can spot the enrichments on the log and disregard them, is the car too rich and EGO is leaning out to the lamda value you are asking it to?
If so, then you may just need to make those areas in the VE leaner, and just possibly adjust the accel a bit higher,if the car still coughs on pedal press.
Mine are currently all on the rich side for different reasons,but i intent to fix those areas to the exact lamda i want and then play with the mat vs tps vs IAT to compensate. Make sure those tables are all 100 for now.
