Hi Guys
I am about to order my VEMS. I would like to tune for closed loop at WOT without MAF...Can this be done with Wideband Lambda, EGT, IAT and Knock of course loop back to the VEMS ECU?
Can you give me advice on what to order from VEMS and if there is anything else I should change to ensure I can remove the MAF and narrowband lambda(btw is this a good idea)
Here is what I have in my cart.
1 x VEMS motronic55 with Wideband LSU4
1 x Bosch knock sensor
1 x MAT sensor
1 x red LCD cased
1 x EGT sensor (K-type)
Rgds
1 x MAT sensor
1 x red LCD cased
Rgds
