vemstune versions
  • A80Avant
    replied
    anyone that upgraded to 1.1.88 from 1.1.81, did you have to change your trigger setting? If not,was this checked with a timing gun again?
    thanks
  • A80Avant
    replied
    i asked a question on the vems forum regarding the 1.1.88 version and if there has been any improvement with the speed sensor issue, because for audis really thats the only thing missing, which would make things a bit more interesting such as fuel consumption calculation and gear depended boost. Having said that, gear depended boost is useless for me at the moment as i have managed to tweak the settings to give me a nice boost curve throught all gears anyway.
  • Bram
    replied
    Damn, been offline for a few months and Vems firmwares keep on coming up. I am not going to dive into it for now, but still looks like it gets better each 10 sub-releases
  • ranz
    replied
    Originally posted by cooperquattro
    hi all...
    my current firmware is 1.1.63
    can someone explain how to upgrade?and to which one?will all current settings be lost or will the settings move over with the upgrade....
    sorry i have had very little use with the vems
    thanks
    Open vemstune and save your config to a fail. Unplug injectors, fuel pump relay and ignition power cables (not needed with versions 1.1.83 and up). Download firmware from firmware web tool. Then from tools->firmware select firmware upload. After update upload previously saved conf file. Then check the configuration because some fields are not going to be same.
    Usable FW are 1.1.81 and also 1.1.88 (there are released also FW between these two, but they are with boost PID problems).
  • cooperquattro
    replied
    hi all...
    thanks
  • ranz
    replied
    Originally posted by Billman
    New version is out that lets you download till 1.1.85....they are still not released yet.
    http://www.vems.hu/download/VemsTune...2010-11-15.exe
    Just installed FW 1.1.85 on my car yesterday, seems to be 0 problems so far
  • Billman
    replied
    replied
    That's why I am saying the wanted to write 1.1.82 there.
    However
    http://195.159.109.134/vemsuk/forum/...ic,1442.0.html
    That just proved it's not a typo
    1.1.83]
    * anti-flooding SafetyMode implemented while uploading firmware.
    * config/table switch modifications, see help for more details
    Click on the anti flooding link
    Safety Mode
    After firmware upload the config may be absolutely wrong, and the ECU can flooding the engine with fuel.
    To prevent this recommended to unplug the injectors before firmware upload.
    * From Firmware version 1.1.83
    1.1.83!
  • Billman
    replied
    However
    replied
    How is it a typo?
    It's not available for download yet however
  • Billman
    replied
    i think 1.1.83 is a typo. Is it safe and tested or should i stay to the known 1.1.81?
    replied
    1.1.83 is also out with the new vemstune
  • A80Avant
    replied
    19/10 is out. datalog flood fixed
  • A80Avant
    replied
    no wonder my windows are fighting against me. install/uninstall/install again....
    replied
    Big change to format and some extra options, firmware 1.1.82 is also out, can't find any info on it though
