anyone that upgraded to 1.1.88 from 1.1.81, did you have to change your trigger setting? If not,was this checked with a timing gun again?
thanks
vemstune versions
i asked a question on the vems forum regarding the 1.1.88 version and if there has been any improvement with the speed sensor issue, because for audis really thats the only thing missing, which would make things a bit more interesting such as fuel consumption calculation and gear depended boost. Having said that, gear depended boost is useless for me at the moment as i have managed to tweak the settings to give me a nice boost curve throught all gears anyway.Leave a comment:
Damn, been offline for a few months and Vems firmwares keep on coming up. I am not going to dive into it for now, but still looks like it gets better each 10 sub-releases
Open vemstune and save your config to a fail. Unplug injectors, fuel pump relay and ignition power cables (not needed with versions 1.1.83 and up). Download firmware from firmware web tool. Then from tools->firmware select firmware upload. After update upload previously saved conf file. Then check the configuration because some fields are not going to be same.
Usable FW are 1.1.81 and also 1.1.88 (there are released also FW between these two, but they are with boost PID problems).Leave a comment:
hi all...
my current firmware is 1.1.63
can someone explain how to upgrade?and to which one?will all current settings be lost or will the settings move over with the upgrade....
sorry i have had very little use with the vems
thanksLeave a comment:
Just installed FW 1.1.85 on my car yesterday, seems to be 0 problems so farNew version is out that lets you download till 1.1.85....they are still not released yet.
http://www.vems.hu/download/VemsTune...2010-11-15.exe
That just proved it's not a typoThat's why I am saying the wanted to write 1.1.82 there.
However
http://195.159.109.134/vemsuk/forum/...ic,1442.0.html
Click on the anti flooding link1.1.83]
* anti-flooding SafetyMode implemented while uploading firmware.
* config/table switch modifications, see help for more details
1.1.83!Safety Mode
After firmware upload the config may be absolutely wrong, and the ECU can flooding the engine with fuel.
To prevent this recommended to unplug the injectors before firmware upload.
* From Firmware version 1.1.83Leave a comment:
However
no wonder my windows are fighting against me. install/uninstall/install again....Leave a comment:
Big change to format and some extra options, firmware 1.1.82 is also out, can't find any info on it thoughLeave a comment:
