Better datalogging using the stock ECU
  • Nuvo
    • Nov 2003
    • 3826
    #46
    I would be quite interested in taking a look at your commented .idb files if you are willing to share?
    I completely understand if you want to keep the results of your rce to yourself.
    • prj
      • Mar 2010
      • 6308
      I will probably post that someday...
      I'll send a PM
        There is some impressive geeking taking place
        • AndyP
          • 6049
          • prj
            • Mar 2010
            • 6308
            Well, I am getting about 49-52hz from it with 12 values on the bench.
            Need to finish up the Winlog driver and field test it.
            • prj
              • Mar 2010
              • 6308
              Winlog driver finished.
              Getting 12 values at a steady 50hz atm.
              Increasing or decreasing the amount of values does not seem to have a significant effect on the data rate.
              Field tests tomorrow.
              • prj
                • Mar 2010
                • 6308
                Alright, so tried it on a running car, with some help from someone who actually has a 2.2T...
                At first it did not work above 2000 RPM.
                Everything went haywire.
                I then remembered that there is some sort of threshold (mappable) in the ECU and it is used to determine whether to run logic.
                Stock it is 2000 RPM, after setting it to 10200 RPM the logging works perfectly.
                However, those routines that are limited by that constant are pretty large, and while the ECU works fine, it's calculations are a bit slowed down by this in theory.
                No idea if it is even noticeable (car revs fine and everything works), but someone did put that constant there for a good reason.
                I also don't really need any of that stuff to run for my routine to work, so it makes me think that something breaks something else somewhere.
                So, I am going to simulate some RPM on the bench, and try figuring out what I need to disable for it to work...
                • prj
                  • Mar 2010
                  • 6308
                  Just to give you an idea, how detailed this is.
                  This is cranking and starting the engine, 1.5 seconds:
                  • Rusty
                    • 18953
                    Sounds like you're really making progress now
                    Specification creep would warrant a WBO2 and EGT probe input too, if possibe
                    • prj
                      • Mar 2010
                      • 6308
                      Can't do EGT...
                      Loggable linear 0-5V AFR input is piece of cake
                      • Rusty
                        • 18953
                        Is that because different thermocouples are calibrated differently?
                        • prj
                          • Mar 2010
                          • 6308
                          Because they are resistance based and the ECU only has spare 0-5V 8 bit ADC's.
                          If you can manage to give a such voltage, so that the result after running through the EGT probe is in 0-5V range, be my guest.
                          Also, for AFR inside ECU you can do this:
                          It's also pretty much pointless to log EGT. It is something that you can easily see on a gauge and check it a couple times. It's not real time data that you need to know where it exactly happened...
                          EGT is checked in a long high gear pull and basically it is either too high or not.
                          • prj
                            • Mar 2010
                            • 6308
                            Demo from my friend in Poland:
                            • Nuvo
                              • Nov 2003
                              • 3826
                              #59
                              Well done. The increased sample rate greatly improves the clarity of the graphs and the responsiveness of the virtual instruments.
                              • rst
                                • May 2006
                                • 102
                                Does this work?
                                Just i guess
                                Audi UrS4 609hp/846Nm @ wheels
                                10.911@210, 1km 268km/h, 1mile 295km/h
                                FATS 2,30 sec
