ok, had to go for a blast to cheer me up and managed to dial out my surge which im pretty happy about. :mischeif:
It seems that maybe the heat has something to do with it. After a motorway cruise pulling in a garage here and there ive noticed its not as bad. Not dropping off if i press the clutch in on the move.
Still drops a little if you blip it under load. Its a little shaky and idling a little higher than it was in tescos when it was stable. Speedo reads 1150 and vems shows 950-1050. I can live with that!
ISV is in wagner location, felt very hot to the touch when i checked the oil.
Feels like a productive eve. Have to see how she behaves in the morn/next traffic jam.
been out for a drive and its not too bad. same as last night. Guess it will need some tweaking to get it spot on. Idle doesnt seem to want to come down to my general idle setting though.
is that the effect of one of the PID? or maybe was a temperature thing made it lower and that why it went up slightly after I went for a drive?
that was excactly my effect of keeping the D high. also in my car once the engine temp goes higher, idle was going higher as well and D was making it worse.
It's such a mystery why idle is such a problem on all these cars and we need different settings. I've had to revert back to my original settings on idle with NO ignition timing.
Using ignition timing makes my engine sound awful and no better that just using the IAC with PID 35 3 7 and Asymmetric PID Conf
Oh no don't give up, tuning idle takes a lot of time, took me months for me to be happy, in the meantime you can disable ISV and run on ignition timing only, A4kquattro has posts on the settings
its great 99.999% of the time but it seems when it gets warm ~50 -60'c it starts to hunt a little. and when it gets up in the 80's and you sit still for any period of time it starts stumbling. when the fan cuts in etc etc.
if I go higher than those settings like 24-25-26 it makes the hunting worse and if I go lower it cant recover from the fan cutting in. So I'm pretty confident that the settings for P are about right.
The I is at 7 any lower and it doesn't quite make its targets and higher seems to make no difference until it starts to cause oscillation.
D seems to do naff all...I thought it helped dampen the oscillation but when I was curious and took it out it still done exactly the same as it did with it.
maybe I should try another ISV and see what changes.
Depends have you got a map you can post up or screenshots of your ISV settings, also remember an unbalanced ve table and ignition will cause the same hunting
there is one further back in this thread but its not current. I have changed my base settings and adjusted my VE table to gain a higher resolution as was recommended. gone back to the req. fuel that peter supplied me with and leaned everything out alot more.
