I have motronic for mine, I was thinking about vems but as jamo pointed out i'd end up getting fed up forever having to tweak it so tbh i'd prefer to just get it mapped and drive the thing.
ill take the initiative and say, aftermarket ECU in the way VEMS is structured gives the owner the opportunity for some to complete involvement in the management, allows for continuous variability of the tuning, is less error triggered by various sensors misbehaving but will allow for lots of functionality regarding wrong values on sensors and engine items. It will allow the use of a more elaborate inlet temperature sensor as well.
Depends on the owners mindset fit and forget or tinkerer, if the stock ecu could have done what I wanted I would have stuck with it but aftermarket has it's place only thing is the top notch ones cost a fortune
That's what is putting me off getting a VEMS.
The main thing is that Motronic is not easy tunable. The END
It is for me
Question is - does average user need to worry all the time about his car? About it not starting?
I can tune my ECU when I have the mood, adjust a few things, then I can drive for a month without attaching anything to it and it just works.
I don't have issues with idle, cold start, warmup enrichment etc, because Audi already did that for me. Better than I ever could.
Thats not what I said Acidburn I said you would have to learn how to correct any issues with the ecu on initial setup and you don't need to keep a laptop in the car that's a myth.
Depends if you spend the time you don't have to mess with VEMS it's perfectable stable and can be left alone, myself and A80avant have a) changed versions b) implemented the new features c) changed engine specs hence the changes
You could easily do a Bram get it mapped once on 1.1.27 and never have to touch it again
Thats not what I said Acidburn I said you would have to learn how to correct any issues with the ecu and you don't need to keep a laptop in the car that's a myth.
You wanna come over here for the winter and show me how your car starts in -25C?
My "crappy" motronic started in -32C with one turn of key.
