problem with vems
  • roger shaw
    • Sep 2008
    • 129
    problem with vems
    Hi all
    had vems for about 18 months,went from 1.1.27 to 1.1.95 about 3 months ago
    since then its had a mind of its own,changes settings
    boost vs tps curve
    boost target 1st gear
    boost refdc 1st gear
    boost alternate settings
    output channels
    engine set up(injector flow rate,put 440 in and 65281 comes up)
    engine is a 3b with rs2 turbo and injectors
    any sugestions would be gratefully received
    my thoughts are that the ecu has a bug in it
    can alter setting when not connected to ecu but when connected it has a mind of its own
    when driving you can feel a slight hesitation on acceleration which I think is the ecu changing the setting
    the above are only some of the setting which are changing
    roger
    What version of vemstune are you using?
    • roger shaw
      • Sep 2008
      • 129
      vems
      Hi
      V3
      config version 1.1.87
      firmware version 1.1.88
      have tried several different versions
      roger
        No the actual version of the vemstune program, certain firmwares are only compatible with the latest downloads from here http://www.vems.hu/download/v3gui/ the latest being 2011-07-20
        • roger shaw
          • Sep 2008
          • 129
          Vems
          Hi
          version 1.1.95
          serial no v3.3_n002588
          where will I find it
          roger
            In help about
            • roger shaw
              • Sep 2008
              • 129
              OK,
              vemstune 0.30.18
              roger
              • cooperquattro
                • Jan 2011
                • 815
                maybe try the latest one
                  Sorry he has the latest one, sounds like the issue s2martyn had, I would email Vems.hu or maybe A4kquattro can help you?
                  • roger shaw
                    • Sep 2008
                    • 129
                    Hi
                    I,ll try the email route
                    thanks roger
                      The last time I had this issue on my Vems what I did was downgrade to 1.1.27 upload the base install map I got from my vems supplier and then update it again to the latest version upload a default map so the scalars get added and then install my active map.
                      What was you upgrade procedure when you did this
                      • roger shaw
                        • Sep 2008
                        • 129
                        Ok,have loaded firmware 1.1.95
                        vems has now stopped changing settings on its own
                        can now put settings in and they stay there
                        also it has stopped shutting down for no reason
                        all I need to do now is tune it
                        thanks for the help
                        roger
                          Sounds like you modified the values in the ecu post 1st upgrade rather than upload a map to create the scalar values in the ecu, glad it is working
                          • A80Avant
                            • 10873
                            • Country: Greece
                            just noticed this, good job!
