DTA S80 PRO on 5 cylinder
  • taycoss
    • Aug 2011
    • 25
    Hi all im new here and thought id say hello and ask a few questions. I am helping a friend fit a dta s80 pro ecu in a quattro turbo rally car. I have sorted out a crank trigger wheel but was wondering about cam sensor. Can a dta use a magnetic crank signal and hall cam signal? or do both signals need to be the same? ie both magnetic or both hall. Are many people using a dta ecu on there 5 cylinder?.
  • Audi_CQ
    • 940
    • Country: Norway
    Can use a combination of magnetic and hall. I'm using magnetic crank and hall cam sensor on my S100. Works fine
    • taycoss
      • Aug 2011
      • 25
      Spot on thanks for that Audi CQ and just what i wanted to hear. Are you running coil packs also?
      • terrybullwon
        • Mar 2006
        • 8782
        I think Auto Mark used DTA on Simon Bainbridges Hill climb S2
        Chef
          Aronmatic had dta in his green s2 speak to him
          • gnutz2
            • Aug 2006
            • 928
            I run my DTA s100 wasted spark with magnetic (VR) sensor with 15-1 reference pins on the flywheel.
            Just set the engine up as a v10 in the settings and it will work.
            I understand all that can be gained by running a cam sensor is a small ammount of economy at lower (cruising) revs, not really what you want in a rally car.
            The ONLY S2 Golf!
            http://www.s2forum.com/forum/showthread.php?t=19402
            10.42@138mph
            https://m.youtube.com/watch?v=0wnkkOfFpXg
            • DJones
              • Jun 2005
              • 2020
              Yes he did and he does in his new RS6 mid engined TT.
              As gnutz2 said i remember Mark saying he set it up in V10 mode.
              • Audi_CQ
                • 940
                • Country: Norway
                Running 5 coils yes (with a HKS Twin Spark amplifier).
                Have run it as V10 in batch mode, but now sequantial with a cam sensor because I want to be able to adjust cylinders individualy.
                • gnutz2
                  • Aug 2006
                  • 928
                  I did not know you could trim individual cylinders with dta, is there an update?
                  The ONLY S2 Golf!
                  10.42@138mph
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    Been there all the time I think. Look under "Sequential Injection and Fan control". There you'll find injector trim for all injectors.
                    • taycoss
                      • Aug 2011
                      • 25
                      What coils are people using? I have a set of denso units from a honda s2000 which fit well. Would there be any probs running these?
                      • dspl1236
                        • Feb 2008
                        • 242
                        bringing this back. what firing order are you guys using?
                        '91 Pearl 3.6 V8 CQ - building
                        '13.5 Jetta GLI - toy
                        '15 Subaru Imprezzzza - work daily
                        hausofdub.com
                          FUGGGGG. Why won't you believe me? 1-2-4-5-3. It's cast right on the head so muppets can't F it up.
                          • driftin jo
                            • Sep 2007
                            • 2222
                            The fact that you have to ask what the firing order is suggests to me you should forget about tuning or even working on your engine in any way, period .
                            • prj
                              • Mar 2010
                              • 6308
                              I know this is old, but, the cam sensor is required for:
                              * Knock control (to determine knock window and cylinder)
                              * Decreasing the load on the coils by a factor of 2. On higher revolutions, running two sparks and two dwell events can overheat the coils, because it's like running the engine at double RPM, and the coils were not made to function at 14000 rpm at high boost.
                              * Misfire recognition
                              * Continous camshaft adjustment (to get feedback for current camshaft position) and it's diagnostics
                              I would say 1-3 are useful for any car. Out of that closed loop knock control directly affects the performance and safety, as using it, you can always run maximum possible spark advance. Without it you have to leave a respectable margin of performance untapped, to be sure nothing blows up.
