Started my fully build engine on VEMS today
I'm total newbie on VEMS so i have some questions. I started the car on the base map which was on the ECU. Only thing i changed was the Req feul (injector Size) on the engine setup menu to 2.5 ms. because i have 870cc VM14 injectors instead of the original ones.
The engine starts fine and runs very nice for aboud 10 seconds en than it stutters and stalls. Just as you can see in the youtube link.
http://www.youtube.com/watch?v=ShZrM6vviok
I also added a log file of the run you can see in the movie.
http://www.2shared.com/file/9aGh6XBE...06-190359.html
Things i noticed:
- There is a red sign which says: Too many Pr. trig
- Lambda don't seems to work. ( As you can hear in the movie i don't have a turbo on so i have made the wideband sensor in the hole for the waste-gate. I don't know of this has any effect on it?)
Things you may wand to know.
Firmware 1.1.81
Config 1.1.81
Anyone know what can cours this?
Tanks
Things i noticed:
Firmware 1.1.81
Config 1.1.81
Tanks
