Bosch temp sender values
  • Kieron20V
    • Mar 2008
    • 1505
    Anybody have working bosch m14 screw in type air and coolant temperature sender values?
    Need them for 034 IIc ecu setup..
    I found a couple of bosch datasheets for different part numbers, and came up with these as guesstimates, do they look any good?
    1994 URS4 Avant RS2+
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    look into the aftermarket ecu folder of the forum
    i have posted somewhere values for the 1.8T air temp sender and the coolant as much as i could measure
    • Kieron20V
      • Mar 2008
      • 1505
      This is the aftermarket forum. 1.8t sensor has different resistance curve than other screw in types.
      • Kieron20V
        • Mar 2008
        • 1505
        Ok, found this
        Looks good, but 034 ecu has stupid set points for resistance.
        • terrybullwon
          • Mar 2006
          • 8782
          Try the Race Technologies forum they have most of the common bosch sensors over there
          Chef
            what about plotting it in the kitchen with a pan of oil, temp probe and a multimeter?
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              thats pretty much how i did it
