Hard start both cold & hot temp
On different car's hardware "sample config" can't log file to see CrankPW
I try to find about Crank PW for Vems,but found many answers for Megatune.
OK most of us 2226 CC but, big or small turbo should be same crank pulse width,
big or small injector cause Req Fuel different so if I'd better ask about % before multiply Req Fuel.
Question is what
1) For Vems % before multiply at Coolant Temp (Pic in red circle) = ?,?
Or Crank Pulse Width at Coolant Temp = ?,?
2) Prime Pulse = ? use or not use
3) IAC Duty While Crank -40,77 = ?,?
Thank you all
Question is what
Thank you all
