will do it again tomorrow mate.it' s now 21.30 here in Thailand.don't forget to get the quote for chipset then i can let my friend knows.
Idle issue on Vems.
Hmm don´t want to bust your thread but have the same problem except it´s high instead... it hangs on 1200 rpm for a while everytime i press the clutch or sometimes is more accurate.
And when cold it´s always high but that i think i know why. When AC is on the rpm is solid 9501995 Audi S6 - AAN (~350hp)
2008 BMW 530xd (235hp)
2011 KTM 990 SMR - custom tuned (120whp)Comment
@Wrath,
If i switch the ac off,the rpm will stay around 1050-1100rpm.personally,it's too high for me.try decreasing IAC Ref Curve for 1% to see if your
rpm drops?one of a few I5 from Asia.Comment
Idle issue on Vems.
Yeh yeh yeh
Krieng did it this morning. Idling with 8 BTDC @ 750 rpm ahaha
I talk with him to increase to 860 rpm and do some fine tune.
Lets wait a few days, allow him to get thing done and he will post what he did with POP.
Next....to tune for PPO with 38 BTDC
Agree with PRJ on the theory.
AAN idling best on low ign timing.
High idling mean somethings not recover btw HW or SWComment
Pop:
I see, my curve starts up at 80% or something and drops as the engine heat goes up.
It aint as flat as yours.
But I have never had any RPM drop ever... maybe I should post my settings and compare them with yours1995 Audi S6 - AAN (~350hp)
750 RPM and 8 Spark Angle can do.
1 hour to tune on road but not complete
pls see in log file
at begin drive like normal
at the end tune AC Off,On,Off and turn the steering wheel left and right
Remark new N80 form A4 1.8
______________________________________
UrS4 MT Y92 Rs2 Turbo.EM e-bay(someone call LOG).
Vems (RS2 Replica injectors, 1.9 BAR Spring).
LS2 coil kit EFI Express.NGK Iradium BKR 9EIX.HKS BOV SQVII.
Cayenne front 6 port rear 4 port(hand break modify).
HOTBITs Full customized suspension/eibach springs.Oettinger RE 18".
Exhaust 2x2.5" stainless steel(no Cat). FMIC 105%Attached FilesLast edited by KRIENG; 28 March 2012, 12:39.Comment
Since we are talking about idle:
what idle settings do you use when the car is idling with heat soak? I have noticed that when the IAT goes at 63 degrees I must enrich the fuelling very much (MAT/TPS correction) in order to have it correct.
How is that setting in motronic?
The logic says that when the IAT raises the fuelling must be lowered because of less oxygen but on the car the opposite happens (at least on idle).Go Holset or Go RS4Comment
Motronic is mass-flow based, so such problems do not exist.Since we are talking about idle:
The logic says that when the IAT raises the fuelling must be lowered because of less oxygen but on the car the opposite happens (at least on idle).Comment
I ended up deciding to purchase brand new Bosch ISV since i'm confidenced my cofig is now good enough but the idle is fluactuating.it sits way
different RPM no matter how much i tried to tweak it.one of a few I5 from Asia.Comment
Keep us updated. I'll be interested to see if it's the effects of a bad isv.Volcano ABY coupe
AntComment
sure, i will be updating if finally i sorts out the culprit. for anyone who getting the bad idle,unstable lambda on idle.
it' ok if you keep the idle aobe 900rpm but once if you want to keep the idle lowered.I assumed our car are now over 15
years on clock.pull off the N80 if it's leaky,get the one.it helps a lot to tweak the idle.I and Krieng found this by luck.
Paid it for few bucks and it saves 3months for tweaking on it.I used the black N80 taken from the later A4.it works out well
but you need a bit bigger on the silicone vacuum hoses.one of a few I5 from Asia.Comment
Pop and me found
New N80 from A4 1.8T is oneway valve so idel no more air leak
(Vems Not control N80 if you want to control it by AUX pin)
and check vacuum line N80 to Canister tank to black&white valve
now idel better smooth
Problem: when deaccelerate RPM go up and down before set to idel RPM especially 1,2 gear.
afterrun fuel cut,resume 1500,1200
ing cell before idel RPM closer idel RPMAttached FilesComment
