Motronic map dump
  • prj
    • Mar 2010
    • 6308
    Motronic map dump
    To whom it may concern;
    This parses any 8 bit (usually 80C5x5) Motronic binary and dumps a XDF from it.
    This is meant to be a starting tool, to prevent lots of manual labor.
    I tried this on some Audi M2.X binaries, both turbo and NA, Opel, BMW M1.X, etc.
    The usage is quite simple:
    Code:
    java -jar mapfinder.jar <bin file> <axis def file>
    The axis def file is optional, but recommended, so that you don't have to manually edit the axes afterwards.
    It's format is like this:
    Code:
    3A;RPM;*40
    3F;LOAD;*1
    etc...
    That will dump you a skeleton XDF to stdout.
    You should probably pipe it to a file (java -jar binfile > xdf-file), then you can open the xdf with TunerPro, and then the real work starts
  • andy10v
    • 5996
    Wow, that is very considerate.
    Sold ABY-stock
    • prj
      • Mar 2010
      • 6308
      A sign of things to come...
