vems communication problem
  • miljan
    • Dec 2008
    • 49
    • Country: Bosnia and Herzegovina
    has a problem with communications between the laptop and vems. I use to communicate rs232 usb cable and driver that I found on vems.hu. Communication is excellent when the laptop is plugged into the charger. When I turn off the charger same moment communication is canceled. I use fv 1.1.95 and 1.1.94 cfg. a new asus laptop that has a Win7. whether the problem may be in vems communication settings or settings of the Prolific driver? Could it be some settings in Win7? please help me to solve this problem
    http://akcrankshaft.com/forum/showth...tid=129&page=1
    Change the settings on the ports so the OS cannot turn them off to power save
    • miljan
      • Dec 2008
      • 49
      is not problem in that. communication works when engine is turned off, but when is the charger of laptop is turned off and engine is running then the communication stops.
      • Ruffiano
        • Sep 2007
        • 1458
        i had the same problem with mine, it turned out to be a bad usb to serial converter.
        • miljan
          • Dec 2008
          • 49
          You're right. I changed the cable and communications work. I do not know how best to set the parameters to vems tune and the device manager, because communication is often breaks.
          • Ruffiano
            • Sep 2007
            • 1458
            I ended up buying a laptop with a serial connection, figured it is the most reliable way of doing it.
            • madpugger
              • Sep 2007
              • 1901
              I am sure there must be a RS232 to wireless solution out there somewhere...
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
                Buy an easysync cable 110% problem free
                • QuattroFever
                  • May 2006
                  • 1360
                  Volcano ABY coupe
                  Ant
                  • cooperquattro
                    • Jan 2011
                    • 815
                    i run serial from day one .usb not good for noise
                      See above post, most USB use a crap generic driver the easy sync has given me zero issues on 4 laptops as recommend by The vems uk form admin rob as its way superior
                      Modern laptops don't come with com ports
                      Rather pay £20 odd for a good cable than buy a new laptop!
                      • prj
                        • Mar 2010
                        • 6308
                        • cooperquattro
                          • Jan 2011
                          • 815
                          Originally posted by prj
                          ????what does this meen???
                            Unfortunately the statement USB is no good because of noise doesn't at first glance make any sense
