My injectors are firing on vems ??
  • ian4455
    • Nov 2010
    • 787
    Still can't start my car on vems, i've plugged a voltmeter into the two injector pins and switched the output on but nothing, no voltage.
  • Kieron20V
    • Mar 2008
    • 1505
    Is it ground missing or +12v? good start.
    1994 URS4 Avant RS2+
    • ian4455
      • Nov 2010
      • 787
      Testing on injector number 1 blue/black wire is down to earth or battery 0Volts all the time, the other brown injector wire is switched to earth / 0 volts when i set output on.
      I've a 3b with a pin swap by the way.
      Guess i missing the 12V + ????
      • Val
        • Apr 2008
        • 630
        • Country: Latvia
        Vems is just switching ground on/off. Injectors should have +12v all the time while ignition is on or fuel pump relay is "on" - don't know how you wired them. Take a multimeter and check it
        5vtq gte
        • ian4455
          • Nov 2010
          • 787
          My fuel pump relay works ok on vems as it primes for 2 seconds when the ignition is on. I need to know where the +12V comes from that supplies the injectors, fuse 28 but thats ok ?
          Its getting a bit cold outside to fault find !!!
          J17 is the fuel pump relay to provide power to fuse 28, if this is set to only prime for 2 seconds in the vems settings then won't this switch of the supply to fuse 28 ?
          • Val
            • Apr 2008
            • 630
            • Country: Latvia
            Did you checked voltage while cranking?
            5vtq gte
            • ian4455
              • Nov 2010
              • 787
              Ok i get 10.5 Volts while cranking, so guess thats ok.
              Coil Packs are firing also but still won't start !
