VEMS issue with EGT
  • ian4455
    • Nov 2010
    • 787
    VEMS issue with EGT
    If the two wires to the EGT socket on the VEMS ecu are open circuit i.e not connected to anything the reading is 1200 deg C correct ?
    If i short the two wires together i should get 20-30 deg C correct ?
  • Val
    • Apr 2008
    • 630
    • Country: Latvia
    1. 0 deg (just as you are using vems without egt at all); if sensor is connected and faulty, you could get 1200 deg. BTDT http://www.s2forum.com/forum/showthr...t=46823&page=2
    2. yes
    5vtq gte
    • ian4455
      • Nov 2010
      • 787
      Its now jumping between two values 300 -450 with nothing connected.
