I can't get spark on the 5'th cylinder on my ABY S2 Avant.
I have tried the igniton output visual in the test mode and there is no spark on cylinder 5 /StepperA
I have changed coil (1,8T coils) and plug,
ohm meassured the the signal wire all the way to the ecu pin 21.
ohm messured the signal from pin 21 to the pcb.
How is the stepper circiut working?
is there one IGBT that feeds the stepper circiut and then delivers spark to all cylinders?
if so the the IGBT should be fine?
Any ideas what might be wrong?
This is the settings in my vemstune:
Why is there a picture showing the conectors on the unversal vems box
ec18 and ec36
Best Regards
Henrik
ec18 and ec36
Best Regards
Henrik
