now then gentlemen, DTA S80 have you have enabled the AntiSlag function.
I know the problems involved with a PROPPER ALS setup, been using antilag for 15 years now but again on I5`s im out of my depth so looking for input
what sort of setup and boost levels are you seeing from a standstill activation?
what idle/ALS valves and throttle bodies are you running?
what sort of noise levels are you getting?
i know there are other better supported managements for this engine available, but i want S80/100 thanks
Sean
Sean
