Vems Latest
  • KRIENG
    • Apr 2009
    • 68
    • Country: Thailand
    Vems Latest
    Is't wrost to try
    firmware 1.1.99
    Vems tune 2012/07/30
    The latest is 1.2.2 for the Audi cars. Read the firmware section about changing the trigger from divdie by 3 to divide by n as divide by 3 is no longer supported.
    • Wrath
      • Jan 2011
      • 779
      whats the big changes?
      1995 Audi S6 - AAN (~350hp)
      2008 BMW 530xd (235hp)
      2011 KTM 990 SMR - custom tuned (120whp)
        Look at vems website
        • diesel des
          • 3896
          I'm still running 1.74 I think. Car starts and runs fine. What I'm I missing out on. I don't mean.list of specs but real life experience.
          • KRIENG
            • Apr 2009
            • 68
            • Country: Thailand
            It hard for me.
            What the number for AAN Urs4 please.
            • A80Avant
              • 10873
              • Country: Greece
              there is no need to upgrade unless, even on 1.2.2 unless you have a problem in your current setup.
              if you are getting a problem of trigger error of some sort that is unsolvable in any way, then try the 1.2.2
              I occasionaly get something above 6500rpm, which doesnt have any problems to the engine, its just signal wise to the ecu so i may be trying that version in the future to see if it makes a difference.
              no free time though
              • europeanme
                • Oct 2005
                • 3817
                no free time though
                lost are we?...
                • KRIENG
                  • Apr 2009
                  • 68
                  • Country: Thailand
                  no free time though
                  Hi you are my master .I used some setting from you that send to Pop.
                  I have 3 problem
                  1) TrE Error
                  2) Log interrupt when high boost high RPM (I didn't press Log off)
                  3) DC injector > 100% (275kpa,4465)
                  what is Sectrig maximum angle (359) can help my problem
                  • Billman
                    • 4129
                    Send the complete log and then point out at regions of interest.
                    Go Holset or Go RS4
                    • A80Avant
                      • 10873
                      • Country: Greece
                      as i said, if you are getting a trigger error with no symptoms from the engine, no coughing or juddering, then its nothing to worry about.
                      But do as Billman said. do a good log, and send it
                      • cooperquattro
                        • Jan 2011
                        • 815
                        no free time though
                        ha ha,glad others have same issue/or not...i get a few Tre errors above,say 6000rpm,so this is just noise transmititing from vibrations????
                        could you take a lok vas??will email you shortly
                        • A80Avant
                          • 10873
                          • Country: Greece
                          i have had it on and off, and put it down to the pin that i have had weld on the 7A flywheel. Doesnt cause any problems to the running of the car, so took no more notice of it.
                          • KRIENG
                            • Apr 2009
                            • 68
                            • Country: Thailand
                            1) Trg Error
                            Still Problem but it's better Thank you Billman
                            may be grinding to closer sensor can help
                            Solved )I changed new USB_To_Rs232
                            Still Problem : I found Injector angle curve can solve a bit
                            What is difference form 210 and 420,500 How to find a best value
                            • A80Avant
                              • 10873
                              • Country: Greece
                              as i thought, its a hardware issue
