Hey folks I'm trying to get my engine started with a VEMS V3, and I'm looking for some help from those who may have a similar configuration.
I picked up the ECU and V3 harness with relays and all, with no pre-configuration from vems.hu.
This system is being retrofitted to my AAN, previously running a full 034efi IIc system; so I'm using the HO Coils, 60-2 trigger wheel, and Siemens Deka injectors.
(GTX-3071R)
All of my wiring is installed
injectors click and coils spark when tested
Primary (VR) and secondary (CamHALL) Triggers are good
timing tests show a good TDC reference during cranking
Batt voltage is ok
fuel pressure is good
but something is mis-configured in my software. Never once does a spark ignite fuel while I'm cranking, I only smell the flooding after cranking a few times for 10 - 15 second intervals... I am relatively new to doing diagnostics on the VEMS software, and somewhat new to understanding what I'm doing when it comes to proper configuration. -I'm learning as I go, reading a lot of forums and published information etc. but the granular detail is beyond me at this point.
What I'm hoping is that someone with a VEMS system, using a 60-2 is around here and would send me a config file. I could look over it to answer some of my questions, and then come back with more informed Q's.
- I think I've truly exhausted my own investigative options, and now I just need a little help to get me going again! If anyone can, I would be indebted!
(GTX-3071R)
Batt voltage is ok
