Config Switch
  • AudiS2Turbo
    • Jan 2011
    • 48
    Config Switch
    Hello,
    how can i switch from config A to config B while offline with my Notebook to make offline validate VE tables and Sparkmaps and so on?
    Or it doesn´t work when offline and not connected with the ECU?
  • dkw_dude
    • 555
    • Country: Norway
    Base setup/config table switching, here you set up which input to use for the config switch. The input must be grounded to signal ground for the VEMS box to be activated!
    http://www.vemssupport.com/forum/ind...ic,1509.0.html If you're not registered here I reccomend doing so.
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
    • AudiS2Turbo
      • Jan 2011
      • 48
      Sorry for the misunderstandig.The config switch works good when the Engine runs.
      How can i Switch from Config A to B (Not connected to the ECU VEMS) I meen Offline Setup.
      Sorry my English is not so good :-(
      • dkw_dude
        • 555
        • Country: Norway
        Ok, I think some of the misunderstanding is in this end for offline editing you need to download config from ECU twice, once with switch in "A" modus and once in "B" modus. When saving file Vemstune adds the letter A or B to the filename automatically.
        Leif-Helge
        • AudiS2Turbo
          • Jan 2011
          • 48
          Thank you.It works pretty good.Thank you
          • dkw_dude
            • 555
            • Country: Norway
            Just happy to help
            Leif-Helge
