VEMS:Aux. Pin out for config switch question.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    this early morning I tried to doing the config switch for E10/E85 fuel.
    I bought the VEMS ECU as used unfortunately there's no wiring diagram
    came as the VEMS.my friend was successful on his config switch.once i
    took a look on the aux. connecter.they ended up with different wire colors pattern.
    So i tired to ground the pin out 3 and found the ADC raw gaue #7 is activated while
    grounding but it stays only somewhere between 4.99V -3.3V when on/0ff the switch.
    the config won't switch between A and B.it didn't work out finally.I ground it on
    somehwere near the door hinge.maybe it's bad ground point?
    here's my connector
    here's took from my friend
    i have also accidentally tried to ground the big red and brown wires while searching
    the correct ADC Raw Channel and i think i'm flooding my motor .
    the engine is now running rough on idle and revving.i hope i didn't damage anything on
    VEMS hopefully.it smell like someone broken the bottle of black label.
    one of a few I5 from Asia.
  • cooperquattro
    • Jan 2011
    • 815
    dont rely on the wire colours or pin location on that plug...you need to check which pin-out on the ecu itself...grounding any wire may result in the ecu being "fried"...think about it you maybe connecting +12v to ground.....pin out is available on vems.hu...which ecu is it????
