I am working on a speed density algorithm for the good old Motronic.
I was wondering, if some aftermarket ECU (VEMS?) has the ability to produce a high enough sample rate log, to show the TDC trigger/crank angle as well as the current MAP sensor reading on the same graph?
Something like this:
http://www.msextra.com/doc/ms3/pix/maplog-1cyl.png
I am right now not sure if it's enough if I sample the MAP sensor at TDC and average the last two readings (so realistically having always the MAP from 1 full cycle of the engine at a fixed crank angle), or if I need to poll the sensor more often during the rotation of the engine and then average the readings.
If anyone has any logs like this on idle and maybe at full load, it would be very interesting to see from the standpoint of an I5 engine...
