tfsi coil conversion issue
  • cooperquattro
    • Jan 2011
    • 815
    After installing the new coils and wiring I have a missfire on on,3,I have done all the checks and it seems that the issue is related to the signal wire from the ecu.I am only getting 0.1 volt whereas the others are 0.5 volts,car is running vems ecu,any input gratefull
  • cooperquattro
    • Jan 2011
    • 815
    So I have found that a driver needs switching in vems,question now is do the trigger on the tfsi coils need +5v or +12v and at what ohm do they fire at,thanks
