vems iat issue
  • cooperquattro
    replied
    Yes sorry.thats the patch,just couldn't remember the exact no.
    Do you guys know the Bosch part no. Thanks Martyn
    replied
    Originally posted by cooperquattro
    Ok cool,I am sure the ecu is set up for ntc(as in resistor on the board)that's probably why the ptc is not working,I will try a new one,I used 2254 patch
    Is there a prefered make to use??ie Bosch etc
    You should be using 2252/256 for a Bosch 1.8T NTC
  • A80Avant
    replied
    Yes indeed. I thought you knew that.
  • cooperquattro
    replied
    replied
    You can't switch sensors between ntc and ptc with VEMS on the fly, only 1 sensor type can be active at a given point in time, there's a resistor on the motherboard that governs this so the ABY ones wont work. You need to try a new sensor like Vas says and check that your using the patch file values in the ecu settings
  • cooperquattro
    replied
    Cheers vas will try another sensor,I allready tryed 2 aby sensors but they didn't work,will try a new1.8 one
  • A80Avant
    replied
    Try another sensor. If its ok then its just the sensor. They are very cheap. I haven't heard of the module in the ecu to break down
  • cooperquattro
    started a topic vems iat issue
    vems iat issue
    My iat seems to be stuck at -9`c,I am using 1.8t ntc type sensor with 2254 patch,if I try the old ptc sensor I get 17`c,but using either the iat or mat reading doesn't move,removing the sensor I get _40`c(which is correct)
