Hello All
As per the title. I am not getting any spark at the moment using Vems AAN ecu.
the car is a 3B, pin swap has been completed. the car has previously been running using this configuration.
I bought the car from ian4455 as an unfinished project however the car started OK when bought. since then the engine block and head has been changed for a different unit with forged internals ect. no changes have been made to the pin configuration for the ECU.
The coils fire when using test mode on vems tune. i cant seem to get a secondary trigger when cranking to fire the coils. could this be a broken hall sensor?
I have done continuity checks on the hall sensor wiring. OK also the 5V supply is good.
I have also double checked the secondary trigger has had the polarity reversed.
setup is as follows:
Coil conversion using 5 TFSI coils. still using hall sensor in dizzy as a trigger.
Firmware 1.1.95
attached is the trigger log and the config file
Firmware 1.1.95
