N80 provision setup problem in VEMS.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    Hi Chaps,
    this evening after i have read the write up how to use the misc output controlled
    N80 in VEMS.once i pulled the vems off i was so surprised that the EC36/36 was
    already in used.i could n't find where the wire goes to another end.I also
    found that on the pin#5 of motronic was already soldered to the EC24/36 on the vems.
    EC24/36 is also the same as EC36/36.It's available for ignition driver(I259,EC24,Channel#6).i assembled the vems.on the vemstune i tried to
    enable the misc 1 and choosed the EC24/36 channel 6 and inverted.
    i found the engine is running a bit roughtly with slightly backfire on the exhaust
    pipe,lambda no changes.i checked the n80 once i pulled off the hose on the connector
    side.i found there's still vacuum trying to drool up the gas fumes from the tank.
    i tried to connect/disconnect connector there's no changes.it seems there's no
    power to energize the n80 valve.no clicking sound via the n80 valve.
    anything i did miss on it?
    one of a few I5 from Asia.
