recommendation for coils
  • miljan
    • Dec 2008
    • 49
    • Country: Bosnia and Herzegovina
    I need new coils for my car. Please recommend me coils which is appropriate for 7A valve cover on 3b engine with vems. My AAN coils has vary low spark and engine has misfire on high boost. I need coils with ignition amlifier installed in it. Please write here catalogue numbers of appropriate coils. The most desirable are coils from audi 1.8 turbo or something else.
    http://akcrankshaft.com/forum/showth...tid=129&page=1
  • Pembo
    • Aug 2004
    • 295
    I've used the 'red' coil pack conversion to great effect . I think they are long enough but the 7A cam cover has a smaller bore where they fit and needs machining out to take them.
    I think someone else will provide the details or take a search here to find the thread with the details.
    Pembo
    quattro - Original 4WD rallying
    Rally Car photos
      TFSi coils as above or LS2 coils produce a lot of spark energy
      • kotnelson
        • Oct 2008
        • 48
        • Country: Thailand
        LS2 coils with low imp spark plug wire. I put coil away from heat.
        Plug gab adjust to 0.5-0.6mm no miss fire at 2 bars boost.
        • Grunf
          • Sep 2014
          • 2
          I second LS2 coils. My 1.8T coils had very short life on E85, 6 months or so. After converting to LS2 coils, I never had missfire again.
