air intake temp and wiring
  • air intake temp and wiring
    guys
    quick question. can the ait be wired in any way. its 2 wire.
    got power to my vems yesterday for first time in 5 years or so. same for sensors. it read ait at 25c. seemed too high to me. it never hardly gets that warm up north its like 8c out there now. to be honest never really paid much attention to it at this level before. need to check the vems profile for it but just thought id ask the question regarding wiring for factory s2 sensor first.
    cheers
    I think its just a thermistor, so shouldn't matter which way round its wired I don't think
      I believe there's a resistance vs temperaure graph on SJM and on S2central or s2-audi under the documentation downloads, as part of the general Audi manual.
        Bingo
        http://www.sjmautotechnik.com/troubl...g/20vairt.html
          034905379B G42 Air Intake Sensor Info
          There is lots of info in my 034905379B G42 Air Intake Sensor Info post too, including the graph:
          http://forums.quattroworld.com/s4s6/msgs/20996.phtml
            cheers guys
            the setting profile in vems maybe out. i run 1.1.23rc code which is like maybe the first version to run auditrigger. alwasy had issues with updating firmware and it runs or ran last time fine for me, could be better at idle etc though. in anything theres always room for improvement.
              I am NOT a VEMS person. I know very little about it (on purpose). That said, in the back of my mind, there is a voice that is saying "Doesn't VEMS want a 1.8T air temperature sensor that works in the opposite direction than the stock AAN/ABY/ADU air temperature sensor?". In fact, I am quite sure that there have been posts here on the S2Forum on that very same topic.
                no you can choose between the 2. different setup for either.
