Innovative LC-1 and stock motronic ECU
  • vwnut8392
    • Jul 2012
    • 418
    I recently acquired an innovative LC-1 wideband setup and i was curious as to if anyone has ever attempted to use the analog output from the LC-1 and feed the signal into the stock motronic.
    The LC-1 has 2 0-5VDC 10 bit resolution outputs are are programmable via the logworks 3 software.
    "The really good drivers got the bugs on the side windows." Walter Röhrl
