guys
whats the current take on upgrading firmware on the vems with a pnp ecu.
whats the current that people are using successfully. it seems that we still gain/lose with certain firmwares.
i looked at the current 1.2.24 iirc and the spark table is smaller than in 1.2.11 thing one is 12x12. numbers escape me at present.
it still on the original auditrigger code of 1.1.23rc. its still in the ecu with the map 5 years after the crash. back then some of you will remember i was struggling to get an upgrade onto it. not one for backing down on the challenge its nearly time to try again.
ill get her going on the known good map and code i already have but once its a goer i will want to pick up on where i left off. i have no idle valve control on that code and to be fair idle and startup could have been better. idle was getting there when it went smash.
your thoughts and experience much apreciated.
cheers
cheers
